head studs
Old Mar 8, 2005 | 12:38 PM
CamaroRSguy's Avatar
head bolts
My car is currently in for a head/ cam swap. I got a call asking if I want to buy new head bolts for 230. I'm kinda short on money, is it worth it?
Old Mar 8, 2005 | 12:41 PM
Mikey97Z's Avatar
Re: head studs
Bolts will be fine, especially if you don't have money to blow.
BTW, I just bought studs from Thunder for $150.
Old Mar 8, 2005 | 04:21 PM
chevyguy3's Avatar
Re: head studs
$230??? i would definitly use ARP head bolts when doing a head swap, but those are only $50. ARP head studs are $115 (more if you get them with 12pt nuts, which youll need if you have large springs), but i wouldnt bother with those unless you are planning on running a lot of boost or very high compression along with a large nitrous shot
at the very least get new stock head bolts. the stock ones are torque-to-yeild bolts and should never be reused. the ARPs are fine to reuse
Old Mar 8, 2005 | 11:17 PM
Dave88LX's Avatar
Re: head studs
$230 for head bolts, WTF? That's a rip dude, unless you misinterpreted something...at any rate, do a search on head studs and see problems people have experienced with them leaking, and make sure your builder installs the correctly!!!!
Old Mar 8, 2005 | 11:21 PM
Re: head studs
$230 must have been for the guy to hand forge and then cut the threads on 'em.
Old Mar 8, 2005 | 11:29 PM
DrewHMS97SS's Avatar
Re: head studs
That is a rip. ARP bolts are ~60-115 depending on where you go. They are tq to yield bolts. Using your old bolts would be like cutting your nose off to spite your face. Pardon the saying. You will not get proper tq or seal if you use them. Tq to yield means they strech.
Old Mar 9, 2005 | 02:21 AM
n2oblkz
Guest
Posts: n/a
Re: head studs
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
May 27, 2015 09:53 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
95chwagon
Jan 13, 2015 09:19 PM
Catmaigne
Dec 25, 2014 12:16 PM
