head only bolt on lt1
Old Feb 26, 2007 | 08:32 PM
formula14.18's Avatar
what kind of power could you make with le1 or le2 heads with long tubes, catback, rockers, ported intake, on a stock bottomend 350
Old Feb 26, 2007 | 08:36 PM
96capricemgr's Avatar
The cam is a cork in the system before the heads. The stock cam is also so small you can upgrade it quite a bit before you compromise drivability atall.
Old Feb 27, 2007 | 11:16 AM
kgkern01's Avatar
I've got a head gasket to change out here in a few months, plan on porting the heads and intake while they are off. I'm expecting at least 335 rwhp or more with full bolt ons and 1.7 RR, which seems to be bolt on LT4 territory. Probably going with LE1 heads to keep costs down and get the car on the road sooner, unless i come upon some unexpected funds then I'll get the LE2 job. My only reason for not doing a cam as well right now is the 150k I just hit on the engine, and hoping to put off a rebuild for a few more years, so no cam so I don't risk spinning a bearing. If you are looking for a way for more power with lower miles, you'll probably gain more from a cam only install over a head only install. Plus it will sound a LOT better.
Old Feb 27, 2007 | 11:48 AM
95LT1conv's Avatar
just get a cam that peaks sooner. people are spinning bearings because they are twisting thier motors to around 7k.ge something like a Hotcam or cc503.
Old Feb 27, 2007 | 04:21 PM
bringBackCamaro's Avatar
I would do the cam and not the heads, much easier IMO
Old Feb 28, 2007 | 02:22 AM
f1camaro's Avatar
Well i know alot of people on here do not agree,but i ported my own heads and noticed a big difference in power even with the stock cam,and i can tell you my port job would be no where near as good as a LE1 head.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
