Head Locator Pins
Old Mar 17, 2009 | 09:12 PM
Fei's Avatar
Fei
Head Locator Pins
been searching for this for about 20mins now. Are the locator pins required if you are using head studs? I got a new block and it is missing one pin and the other is pretty messed up. looks like it was hit with a hammer a few times.
Old Mar 17, 2009 | 10:15 PM
MachinistOne's Avatar
Yes, needed - machine shop will have them. You'll need a slide hammer to remove them.
Old Mar 17, 2009 | 10:27 PM
Fei's Avatar
Fei
? how would i get them out with a slide hammer?
Old Mar 17, 2009 | 10:36 PM
Use the correct jaw to grab them with the hammer and slide hammer away.
Old Mar 17, 2009 | 10:38 PM
Fei's Avatar
Fei
oh... the one that is in there is pretty much flat. looks like the guy before me tried to hammer them out... or maybe that's in. Wonder if there is a pin in the block then? would this cause issues? any recommendations?
Old Mar 18, 2009 | 09:20 AM
ulakovic22's Avatar
Look at the one that's missing to get an idea of the size shape of the hole and either try to drill it out like you would extract a broken bolt or you can try to pry it out. Has your block already been machined and is ready to go? If so you need to be carefuly not to nick or scratch your deck.
The pins are needed to keep the gasket from moving and causing leaks.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
cmyname1
Feb 19, 2015 08:38 PM
