head install guide
head install guide
Where can I get a head install guide? I did a search and didn't come up with much. I know there is probly not much to it, but I like guides. I did my cam swap with a guide and it was much easier. How long to swap my heads out, total time? I have the GM manual for my 1996 Camaro, so I will be using that for sure. I checked the Project Transam site but the head/cam site is down. Anyone?
I might catch L from here but I found out this books really helps, more so than any website I have found. Plus lots of pics. $15 from Amazon.
Useful Book
Useful Book
heres one http://www.afrashteh.com/guide/install.htm
not certain whos it is (Shoebox maybe?
), but i used it when i did mine and it worked fine ( along with the haynes manual and help from this site, but i did heads/cam at the same time, so...). i would venture to say that if you did the cam, youll find doing the heads a breeze.
hth and good luck
), but i used it when i did mine and it worked fine ( along with the haynes manual and help from this site, but i did heads/cam at the same time, so...). i would venture to say that if you did the cam, youll find doing the heads a breeze. hth and good luck
hth and good luck
If you have done a cam swap, you won't have any problems, especially with a factory manual.
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
