Head Gasket Replacement
Old Apr 25, 2009 | 01:08 PM
toegead93's Avatar
Ok, I started my head gasket replacement without the directions I pritned from this forum. Now I can't find them, can someone point me to a link please?
I have two questions regarding my repairs. One, how do I remove the fuel rails? Two, the oil and coolant looks great after draining. Is it possible to have a blown head gasket and not have the two mix?
Last thing, in the middle of my repairs today I got a call from my salesman, my new 2010 has a VIN and is in transit. That is good and bad, because I was really hoping to fix the Z28 first. Thanks in advance.
Old Apr 25, 2009 | 05:43 PM
crazypurgatory's Avatar
Sure you can have a blown head gasket and not have your coolant get into your oil all depens on where it blew out.
You can try Shoebox's web page he's got a lot of info.
http://shbox.com/1/4th_gen_tech1.html
Old Apr 25, 2009 | 07:26 PM
toegead93's Avatar
How are 1993 fuel rails different from 94+ rails? Once the two retaining bolts are removed from each rail will the injectors pop off the same as 94+?
Old Apr 25, 2009 | 07:55 PM
I've never took of my fuel rails so I can answer you queston but if you look at Shoebox's web page it has pictures of them .
http://shbox.com/1/drawings_exploded_views.html
Old May 1, 2009 | 05:11 PM
toegead93's Avatar
The problem I see is the '93 fuel rails are different. I cannot get them off because then line in the back curves down behind the intake. The only way I see is to get the fuel lines out of the way which means disconnecting them. I was trying to avoid this though. Anyone have experience with '93 fuel rails?
Old May 1, 2009 | 05:15 PM
SupplySgt.'s Avatar
Since nobody seems to have noticed, congrats on the 2010 being in transit. I wish i could afford to have one in transit.
And yes it is possible for the two to not mix.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
