head gasket question
This may sound like a dumb question, but can you reuse a head after you clamp the heads down, even if the engine has never been run?
When checking my piston ring to groove clearance, I never paid any attention to the oil rings and when I went looking for more arp moly lube, I found some "oil ring support rails" that i forgot to install
I bolted the heads on last night and was hoping I could salvage the gaskets
Thanks for the input guys, I appreciate it.
I can't believe I missed somethin like this, it's the first time I've ever seen a piston require a spacer for the oil ring assembly, but I shoulda noticed the huge *** gap in the oil rings
