Head gasket question?
Old Jul 23, 2006 | 05:21 PM
wrd1972's Avatar
I need to remove one head to replace a damaged valve.
I am not planning on removing the second head.
Should I use a GM gasket since I am only doing one head or can I use any type of aftermarket gasket?
What gaskets do you guys like, please give part numbers if you have them.
Old Jul 23, 2006 | 05:23 PM
OBE1 95Z28's Avatar
Re: Head gasket question?
If you have a GM gasket on the other side, I suggest you use the GM gasket to keep the thickness the same. I'm using Felpro's and they hold up great.
Old Jul 23, 2006 | 05:24 PM
JustNO's Avatar
The 2 gaskets should be same you know? at least thickness MUST be same ..
Old Jul 23, 2006 | 05:25 PM
JustNO's Avatar
IMO pull out 2 heads and get Felpro 1074 , be cool..
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
