head gasket : felpro 1094 : LT1 ??
Old May 6, 2007 | 10:27 PM
Sporty-X's Avatar
i've seen a thread talking about a 0.015 head gasket for LT1 : Felpro 1094. this gasket is listed as a GEN 1 gasket . Does it works with LT1 ?? are the LT1 and Gen 1 gasket the same ?
Old May 6, 2007 | 10:59 PM
cnorton's Avatar
They are NOT the same. The thinnest head gasket I've seen that will work on reverse-flow heads is the SS Impala gasket. I believe that they are just about 1/2 the thickness of the normal LT1 gasket found on the Z28.
Old May 6, 2007 | 11:32 PM
Sporty-X's Avatar
ok. what is the ref to get such gasket ?
can i get it through summit ?
Old May 6, 2007 | 11:52 PM
cnorton's Avatar
You might be able to order through Summit or Jegs if you use the specific part number for a 5.7, LT1, 96 ImpalaSS head gasket. I don't have it at hand. Just about any NAPA or other reputable parts source can provide the number.
If that doesn't work and expense is no consideration you might try:
http://www.cometic.com
They sell custom thickness multi-layer steel gaskets.
Old May 7, 2007 | 12:21 AM
Sporty-X's Avatar
oky thanks a lot for the info
Old May 7, 2007 | 01:08 AM
seawolf06's Avatar
Mr. Gasket makes the thinnest common head gasket for the LT1. It is .026" thick. The Impala HG is .029" thick.
The stock LT1 HG is about .049" thick.
Old May 7, 2007 | 11:10 AM
95ttoplt1's Avatar
^ Yep yep, I run the Mr G's and they are thin, The thin Impy felpro's were thicker and designed for Iron heads so they are missing a coating or somthing IIRC.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
