head gasket : felpro 1094 : LT1 ??
i've seen a thread talking about a 0.015 head gasket for LT1 : Felpro 1094. this gasket is listed as a GEN 1 gasket . Does it works with LT1 ?? are the LT1 and Gen 1 gasket the same ?
They are NOT the same. The thinnest head gasket I've seen that will work on reverse-flow heads is the SS Impala gasket. I believe that they are just about 1/2 the thickness of the normal LT1 gasket found on the Z28.
You might be able to order through Summit or Jegs if you use the specific part number for a 5.7, LT1, 96 ImpalaSS head gasket. I don't have it at hand. Just about any NAPA or other reputable parts source can provide the number.
If that doesn't work and expense is no consideration you might try:
http://www.cometic.com
They sell custom thickness multi-layer steel gaskets.
thanks a lot for the info
