head gasket
Old Dec 22, 2004 | 06:50 AM
red 95 z28 lt1's Avatar
head gasket
im getting a le2 package and i need head gaskets at .29 or .30 thickness. which company makes them and what part #. im not using cometics
thanks
Old Dec 22, 2004 | 07:06 AM
sssalah's Avatar
Re: head gasket
The iron headed LT1 of the b-body has a thinner head gasket.
Old Dec 22, 2004 | 01:54 PM
96capricemgr's Avatar
Re: head gasket
The b-body LT1(iron heads) used a .029 right from the factory so one that thickness should be as easy as calling a GM parts source and telling them you have a b-body.
Old Dec 23, 2004 | 05:06 PM
arnie's Avatar
Re: head gasket
Do aluminum head applications require a different spec gasket than what oem spec'd for their iron headed models? Or, are they identical, other than thickness?
96WS6TA's Avatar
Re: head gasket
I have been using the Impala head gaskets in my LT1 for 6 years and over
60,000 miles without any problems.
Old Dec 23, 2004 | 05:09 PM
arnie's Avatar
Re: head gasket
That you were able to see, or are you referring to something you might be able to sense/feel?
Old Dec 24, 2004 | 10:00 AM
96WS6TA's Avatar
Re: head gasket
Hey arnie, not sure what you are asking, but I have not had any problems with the headgaskets like coolant leaks or a blown headgasket. I haven't had the heads off so its kinda hard to see what is going on there. I do change my coolant (Dexcool) regularly and I am not making that much power. I think if I were planning to make big power or use NOx I might think twice about using these gaskets.
Old Dec 24, 2004 | 12:27 PM
arnie's Avatar
Re: head gasket
Just a thought as to the (if any) chemical reaction of gasket with the aluminum surface.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
