Head coolant line problem
Old Mar 23, 2008 | 09:10 PM
Ironxcross's Avatar
After I put in my new heads, I've developed a small leak that seems to be coming from the back on the passenger side head. I've used both rubber washers with high temp rtv and tightening the bolt a few times, but still I have a leak. Any ideas?
Old Mar 23, 2008 | 11:09 PM
GreasyB's Avatar
I did not use any rtv with the seals on mine and no problems yet. Maybe try getting new seals and putting them on with no rtv. But make sure to clean surfaces good.
Old Mar 23, 2008 | 11:15 PM
No RTV should be used or needed.
Old Mar 23, 2008 | 11:22 PM
Ironxcross's Avatar
well that seems like the solution right there.
Old Mar 24, 2008 | 08:23 AM
ZDriver96's Avatar
yep no rtv... Make sure your using the right head seals.. There are other seals that will look like they will work but will leak.. Just make sure they are the correct part and undamaged (if u installed your old ones or used ones)
calaban
May 18, 2020 06:43 PM
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
