which head/cam setup?
Old Jun 1, 2005 | 12:50 PM
Kearn's Avatar
hello,
i have a 94z28 m6 with 130,000 miles. i have headers, full exhaust, and cai. im trying to get 350-400 rwhp out of this setup. i have a few combos in mind and was wondering which you guys recommend. please keep in mind that price is a factor as im on a tight budget.
1.) le1 package
1.6 Comp Pro Mag NSA roller rockers
guide plates
7.2" hardened pushrods
timing chain
gaskets
30 lb inj.
4.10 gears
tuning.
2.) le1 heads
combination motorsports cam kit
timing chain
30 lb inj.
4.10 gears
tuning
3.) combination motorsports stage 2 kit
30 lb inj.
4.10 gears
tuning
also, do you guys recommend i get lifters? and if so which ones should i get? thanks a lot for any help you can give me. i appreciate it a lot.
kearn
Old Jun 1, 2005 | 06:32 PM
MeanGreen97Z's Avatar
Re: which head/cam setup?
I think a rebuild is in your future before heads/cam.
Old Jun 1, 2005 | 06:39 PM
jkipp84's Avatar
I'd contact both Lloyd and CMS and talk it over. You list some parts in all 3 options, but none cover the entire picture. Things like fluids, filters, gaskets, and other odds and ends crop up and bloat the overall cost like you wouldn't believe.
Old Jun 1, 2005 | 07:18 PM
Bersaglieri's Avatar
-Dustin-
Old Jun 1, 2005 | 09:45 PM
slomarao's Avatar
Like said before a rebuild may be in the very near future if you go into the top end. If you do, I would get a smaller cam and only rev it to 6k. Rpm's and a high milage motor are not a good combination. How is the condition of your shortblock? I would buy your number 1 combo.
Old Jun 1, 2005 | 10:14 PM
1racerdude's Avatar
Let Loyd pick your cam after he does the head's then you will have a matched setup. Guarantee it will be better than CMS setup.Talk to Loyd about the HP ya want to make,he will plumb ya up on what ya need.
Your stock lifters will take ya WAY past where ya want to go on HP.
Old Jun 2, 2005 | 06:52 AM
OldSStroker's Avatar
Originally Posted by 1racerdude
Talk to Loyd about the HP ya want to make, he will plumb ya up on what ya need.
I like the way you put that.
Old Jun 2, 2005 | 09:56 AM
1racerdude's Avatar
Thank's
Old Jun 2, 2005 | 11:17 AM
Quickshotkimber's Avatar
I agree with the others, I would do a budget rebuild before you add any power. It will be MUCH cheaper to do it before you damage anything.
As far as combos go, there are alot of choices out there. My stock heads are ported by a guy named Eric Bradby. You may not have heard of him, but I'm sure that you have of Joe Overton. The Fastest NA LT1 T/A in the world. Eric ported his heads as well. I figured he must know what he is doing, and as my car has shown, he damn sure does. Make a list of the guys running those times and I assure you, it will be a very short one. The best part is the price. I hear that he only charges between 8 and 900 dollars. No stage #s needed. He ports every head to run!
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
