Head and cam install/117k with front seal leak
Old Nov 30, 2003 | 08:09 PM
Crackhead's Avatar
I have a 94 Z28, with 117k and an oil leak from the front crank seal. Is it worth fixing the leak and putting on the new heads and cam, or does this sound like a mandatory shortblock install? If it will hold up I'd just fix what I have but if this sounds like the end I'll do the shortblock. I know the hardcore guys will say just do the shortblock, but if I can, I'd like to wait until I can afford a 383 if it's totally necessary. Thanx for the advice!!!!
Old Nov 30, 2003 | 08:20 PM
Compstall's Avatar
If you get that far into it changing the heads/cam, it's not all that hard to throw in a new seal.
Old Nov 30, 2003 | 08:55 PM
Crackhead's Avatar
Thanks COMP, but do you think that coupled with the mileage is cool????
Old Nov 30, 2003 | 09:41 PM
fastbird96's Avatar
I just installed heads and cam at 138k miles. My cylinder walls looked like they were from a new motor. So you will probably be fine. A lot depends on how well you've took care of the car. Like frequent oil changes, etc.
Old Nov 30, 2003 | 09:46 PM
Crackhead's Avatar
Thank FB96, My problem is I just got the car. I think I'll go ahead, hopefully my cylinders look ok.
Old Nov 30, 2003 | 10:04 PM
jasons93z's Avatar
These cars run like the energizer bunny Go ahead with the h/c combo
Old Nov 30, 2003 | 10:11 PM
Crackhead's Avatar
Thanks Jay, That's exactly what I needed to hear.
HectorM52
Jul 30, 2017 11:46 AM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
