Head bolt washers???
Old Jan 26, 2007 | 05:16 PM
lilronjohnson693's Avatar
i am gonna install my le1 heads next week and i can't find washer for my heads anywhere(dallas tx. area). i was thinking can i just go to a hardware store and match up some washers??? will this be safe???
Old Jan 26, 2007 | 05:31 PM
RE AND CHERYL's Avatar
How many do you need?
Old Jan 26, 2007 | 05:48 PM
34 washers
Old Jan 26, 2007 | 05:56 PM
Sorry. I've got about 10 lying around. Thought you might just be missing a couple I could throw in an envelope for ya.
re'
Old Jan 26, 2007 | 07:19 PM
seawolf06's Avatar
I didn't even know you were supposed to use washers??? My old heads didn't have them and I didn't use them on the new ones.
Old Jan 26, 2007 | 08:01 PM
I'm pretty sure the stock bolts don't have washers. I've got about a set and a half of ARP bolts and they do have washers.
Old Jan 26, 2007 | 09:23 PM
SS RRR's Avatar
I take it these are ARP heads bolts? If so, just call ARP and get a set. They aren't that expensive.
Old Jan 26, 2007 | 09:57 PM
no they aren't arp bolts they are felpro bolts. i don't have time to order the washers as i am installing engine and trans monday morning
Old Jan 26, 2007 | 11:40 PM
Kevin Blown 95 TA's Avatar
You have to be aware that some washers need to be chamfered on one side to match the radius of some head bolts. For instance the stronger ARP bolts have a radius on the under side of the head and if you use an ordinary hardened washer, it might not let the head bolt tighten flat on the washer. Just something to be aware of. Also, hardware store washers might be uneven thickness which is bad. The best washers are ground flat to be uniform thickness.
Old Jan 27, 2007 | 01:03 AM
seawolf06's Avatar
Nevermind, my ARP bolts DID have washers. doh!
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
