head bolt sealant
Old Jan 13, 2004 | 10:36 PM
TUFF LT1's Avatar
head bolt sealant
I was just wondering if I should use the ARP sealant or just buy some good sealant from the autoparts store when installing my head bolts? Also what thread lock does everyone use? Thanks
Old Jan 13, 2004 | 10:46 PM
QCKZ28's Avatar
i used generic thread sealant (not the tape kind)
its basically the same thing.
jesse
Old Jan 13, 2004 | 10:51 PM
AsianSensation's Avatar
Permatex thread sealant from AutoZone. Used about 3 tubes.
Edit-Permatex thread lock (blue tube) from AutoZone.
Old Jan 13, 2004 | 10:53 PM
QCKZ28's Avatar
that is what i used, you jogged my memory
its about $2 per tube
jesse
Old Jan 13, 2004 | 11:12 PM
Brandon 95 Z28's Avatar
I am using the gm teflon thread sealant, and ARP head bolts. Is everyone still torquing their ARP bolts in 3 sequences as well?
Brandon
Old Jan 13, 2004 | 11:15 PM
Brandon
Of course.
Old Jan 13, 2004 | 11:21 PM
TUFF LT1's Avatar
what do you mean by three sequences?
WS Sick's Avatar
I used the permatex pipe sealant with teflon. It is pretty much the same as the ARP stuff but cheaper.
Old Jan 13, 2004 | 11:22 PM
QCKZ28's Avatar
torque all the bolt in sequence to 15lbs, then to 35lbs, and finally to 65lbs.
if you dont you could warp your head
jesse
Old Jan 13, 2004 | 11:24 PM
Torque the bolts initially to 40 ft-lbs, then 50, and then the final torque spec all in bolt sequence.
Old Jan 13, 2004 | 11:26 PM
TUFF LT1's Avatar
OK I was wondering. I was a little confused about that. Thanks for clearing it up.
Old Jan 13, 2004 | 11:27 PM
TUFF LT1's Avatar
Which is it?
Old Jan 13, 2004 | 11:30 PM
You should follow ARPs recommendations. I followed AFR recommendations for their heads.
Old Jan 13, 2004 | 11:35 PM
QCKZ28's Avatar
Which is it?
either one will work just fine
there is always 2 ways to kill a chicken
jesse
Old Jan 13, 2004 | 11:38 PM
TUFF LT1's Avatar
Ok I guess I've done everything right so far so I'll spend the estra $ to do what ARP says. Thanks AsianSensation I really appreciate all of you're info. Thanks so much
