Having some running issues.
Old Apr 12, 2005 | 10:49 PM
ChevyTuffD.A.'s Avatar
I just got done with my cam install last week. It usually drives fine but tonight i had a pretty bad problem. The car was running good and i parked it and went inside for like 15 minutes. I come back out and start it up and it dies as soon as the idle came down. When i turn it over it acts like it wants to start but wont. If i let it sit for a minute and try it again it starts up for a second but dies right after that. The few times i actually did get it to run I gave it gas to try and keep it running but it would not respond to at all except for a couple times I had it to the floor and all the sudden it would respond and rev up smothly but then just die right after that, it did this a few times. Its almost like something just decided to work all the sudden and respond but then just die. The opti only has like 5k miles on it. The fuel pump has about the same but I have gotten the fuel tank VERY low a few times but i cant beleive it would burn up that fast. Anyone have any ideas as what the heck might be going on here???
Old Apr 12, 2005 | 10:56 PM
The Cartel's Avatar
Re: Having some running issues.
Next time it does it, unplug the injector wires and wait about 5 min. then try to start it, if it fires up let it run tell it kills it self. I'm betting it's in the tune and the ecm is dumping to much fuel in there.
Jason
Old Apr 12, 2005 | 10:59 PM
Just for the record, the ECM isnt tuned for the cam yet.
Old Apr 12, 2005 | 11:03 PM
The Cartel's Avatar
Then I gurantee I'm correct.....When it does it pull a plug and see if it's wet...
Old Apr 12, 2005 | 11:55 PM
Would it just be a once in a while thing bc it hasnt done it this bad since I got it running. When its not doing this it runs great.
Old Apr 13, 2005 | 01:45 AM
Well I just went out and found my problem. Tried to start the car and prime the fuel pump. I didnt have a fuel pressure tester but I did the old press the schrader valve needle in with a screw driver and I got ZERO pressure to come out of that baby, it was bone dry in there. I cant hear my fuel pump come on either so I guess I need to go to AutoZone and get another one for free seeing as how this one is like 8 months old. Good guess tho Cartel.
Old Apr 13, 2005 | 05:59 AM
slopokrodrigez's Avatar
Does the fact that AZ fuel pumps have free replacement make up for the time you have to spend replacing them????? Stop wasting your time with that junk and either buy OEM or a high quality aftermarket. One day that AZ crap will leave you stranded or worse. Just imagine pulling out onto a freeway and you can guess the rest.
Old Apr 13, 2005 | 11:42 AM
Well I would be ALOT more pissed off right now had I not done the trap door method when I changed the pump last time. At least now I can change a pump in 30 minutes or less. Ill have to wait till I can afford a better pump.
Old Apr 13, 2005 | 03:43 PM
4DrZ's Avatar
Hey Where Is The Maf I Paid For? Are You Ripping Me Off Or What?
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Snoman73
Nov 17, 2014 07:22 PM
