Having problems with idle after 58 mm TB install.
Old Jun 25, 2003 | 08:02 AM
  #16
REPO's Avatar
Yup, thats all I changed.
I think there is actually something else wrong, just being coincedence.
I tried new O2 sensors (both) last night and it fired up and idled much better, but still shook some. Took it for a drive and it was ok, but then slowly started running like crap again. It is loading up with fuel horribly.
I'm a bit lost at this point.
Old Jun 25, 2003 | 09:58 AM
  #17
Buttercup's Avatar
You're absolutely, positively sure that the intake elbow is mounted on the TB correctly and there are no tears in it? Just sounds like an intake leak after the MAF to me. Double check every inch after the MAF and all around the lip over the TB. Aftermarket TB's can give some problems but it's usually nothing like that!
Old Jun 25, 2003 | 11:29 AM
  #18
CJ's Avatar
CJ
Intake leak after the MAF is what is also sounds like to me.
Whats happening is...the motor is sucking in umetered air causing it to lean. The PCM try to compensate for it by bumping up the BLMs to richen it up based on the o2s. This process contunues until the BLMs are maxed out and the PCM cant make any more corrections. Eventually it will reset itself and start over. Thats why you see them drop back to 128 and contunue to rise again.
Old Jun 28, 2003 | 04:13 PM
  #19
REPO's Avatar
Well after sitting a couple of days, I put some fresh fuel into it. Like I stated before, I also have also installed new O2 sensors.
The car runs great now. Seems to be working ok at all RPM levels. Now I just have to do some new VE changes and trans table changes and I should be set.
Thanks for the help guys!
Reid
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
thenewkid
Nov 18, 2014 12:57 PM
Zone
Aug 2, 2002 04:36 PM
