Having Issues....
Old May 8, 2005 | 03:21 PM
97 RedSS's Avatar
Having Issues....
Yesterday while driving home my car starting acting very wierd...It was loading up while driving and doesnt seem to have much power at all..If I stop at at light the car will not idle by itself..Also, it is smoking out the back-(White smoke I believe and there was a brown "milky" substance on the ground also..)
There are no abnormal noises that I can hear...Oil pressure was a little lower than usual but within specs.
Here is what I did today to start the troubleshooting fun..
1)Drained oil- Looked like normal and found no bearing material
2)Pulled raidiator cap and it wasn't low..
3)Pulled valve covers and found nothing abnormal...
4)Pulled spark plugs-few of them were carboned up a little but nothing major
I plan on putting a Fuel Pressure gauge on it to rule that out also...
It doest seem like an Opti issue since I usually see most of those issues involve a high rpm miss....
Any suggestions or advice?
Cody
Old May 8, 2005 | 03:27 PM
BadRag's Avatar
Re: Having Issues....
"brown Milky stuff"....sounds alot like a head gasket, your getting coolant in the oil.....Just a guess, Sorry Bro...
Old May 8, 2005 | 11:17 PM
97 RedSS's Avatar
That was my first assumption but I want to make sure before I tear her apart...Is there a way to isolate this problem so I can narrow it down...(ie compression check?, pressure guage on the radiator?...)
Is white smoke usually signs of water in the oil?
Cody
Old May 9, 2005 | 12:04 AM
SoloExceptional's Avatar
I thought white smoke would be oil burning off, like a blown headgasket and if I'm right(correct me if I'm wrong) a compression test would tell you that, you would be bleeding off pressure instead of holding it..
Old May 9, 2005 | 12:08 AM
turbo_Z's Avatar
A head gasket leak can leak into the chamber which can cause a deal cylinder and will definitely produce white smoke. A leak doesnt always mean coolant will find its way down to the oil too so dont rule it out just b/c the oil looks fine.
Old May 9, 2005 | 12:11 AM
If he pulls his plugs and there is oil on them that's a good sign of a headgasket leak as well right?
Old May 9, 2005 | 12:18 AM
turbo_Z's Avatar
Not really.. oil doesnt run thru the head gaskets so oil on the plug would indicate bad rings.
Old May 9, 2005 | 12:19 AM
Could bad rings cause it as well? The only other time I had a car with that problem is when I had a cracked head,.
Old May 11, 2005 | 04:42 PM
97 RedSS's Avatar
Welps, I found the culprit!!!
I had almost everything torn down since I was thinking it was the passenger head gasket...I decided to preform a compression check first to ensure that was my problem..Well, I did a check and everything looked okay
For some reason I decided to prime my fuel pump and then bump the starter over to see if any injectors were possibly sticking open...Well after priming the fuel pump I could actually hear an injector leaking on the passenger side dripping into the cylinder...Sure enough, once I bumped the starter fuel shot everywhere out of that cylinder
Please no one make my mistake and purchase Accel Injectors!!!!!!!!
Old May 16, 2005 | 10:42 PM
97 RedSS's Avatar
Read my above post so you know NOT to buy Accel Injectors!!
Cody
Old May 16, 2005 | 11:00 PM
FastZinTennessee's Avatar
I think I'm going to buy some Lucas injectors that Racetronix sells. They seem to be priced reasonably. Do you know if they are any good?
Old May 16, 2005 | 11:19 PM
97 RedSS's Avatar
I'll be doing some research tonight on that topic...So far, all I have seen is positive on the Lucas Injectors...
Cody
Old May 17, 2005 | 08:35 PM
97 RedSS's Avatar
Do you guys think any harm could have been done in the 20mins I drove home w/ the #6 injector stuck open? I guess the o2 sensor was going crazy thinking it was too rich and that was why my car was running like crap..I did a compression check on #6 and everything was ok, so it didnt wash out my rings...
I alrdy ordered my 42lb lucas injectors
Cody
Old May 18, 2005 | 01:04 PM
My only concern since your compression came back fine is excess fuel in the oil, but you said that one of the first things you did was change it, so I think you're fine.
NVetro
Nov 20, 2008 04:50 PM
oneqwkfbody
Jun 15, 2008 10:29 AM
CHOPSZ28
Sep 10, 2006 07:55 PM
