Has happened a few times....where when i start the car up the RPM's guage doesnt read
Old Aug 7, 2007 | 01:51 PM
chesee48's Avatar
Its happened a few times over the past year or two when i start the car up and then start to drive around, it takes a few min for the RPM's to start reading on the dash....granted i drive the car like 400-600 miles a year now, but i was wondering if this is a common thing or if there was any to fix this?
thanks!
Old Aug 8, 2007 | 10:34 AM
Z28SORR's Avatar
Not common. Most likely, is a bad connection or ground. Trans. sending unit is exposed to the environment, so I would start there. And work my way up to the tach.
Old Aug 8, 2007 | 11:12 AM
Eck's Avatar
Eck
I had this happen to my car twice last summer. It was only after the car sat in the heat all day. I would start it up and the RPMs wouldn't read for the first few minutes or so. After that it was fine. I just assumed it was something heat-related since it hasn't happened since.
Old Aug 8, 2007 | 12:29 PM
nb 96 z's Avatar
If it happens again, tap on the front of the guage cluster window. Sometimes the needle just gets stuck.
Old Aug 9, 2007 | 01:24 PM
EKO's Avatar
EKO
+1 for stuck needle. I have to do it every time. Give the dash a good smack and it will pop up.
Old Aug 9, 2007 | 02:01 PM
dannyum89's Avatar
I had that problem but it was more serious then a stuck needle. My crank sensor went out. Car would still start but had no tach. Although I dont think you have a crank sensor on a 94 but im not sure.
jj71787
Dec 30, 2014 02:15 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
teedoff59
Aug 8, 2002 01:36 AM
