harness question?
Re: harness question?
all that should be needed is to splice the single connector into the 95 harness, IIRC, all the correct wires are there, just in 2 connectors instead of 1
I'll look into it to make sure that all the wires are there
EDIT
look here, the connectors I am speaking of are C100(94 and 95) and C105(95)
http://shbox.com/1/harness_connector_faces.htm
looks like there is just 1 wire you will need to move from C105 to splice into a wire in C100(C105, wire B, splice into C100 wire K), and it will work
all the other wires in the C 105 connector look to be traction control(Or V6) related, and 94s didn't have the optional traction control
I would try starting/running it with all the wires left alone, since the wire inn C105 MIGHT be for traction control, if it is, it will all be good without it
cool thanks for the link.. i think that if i can't figure out what is wrong with my harness i am just going to get another one.. and just seeing if i can find more applications that are the same..
IgorT.455/406
Mar 12, 2015 03:39 AM
