harness corrosion
Old Sep 26, 2004 | 06:58 PM
Liquid Teal's Avatar
shoebox
for a possible code 16....
is there anything other than maybe a kanker on the harness to cause this ?
the complete opti is new.
would the corrosion be at the terminal end or throughout the harness ?
thanks,
Old Sep 26, 2004 | 10:43 PM
Re: shoebox
Terminal ends would be the greater suspects. You would also want to be sure no corrosion is present on the terminals on the opti, itself. A corroded connector will transfer corrosion to the opti terminals, so both would need to be cleaned.
G-BODYT56
Jan 14, 2022 11:14 PM
drt
Sep 27, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
Thirim
Jul 30, 2015 01:29 PM
