Harmonic Balancer
Does anybody know where I can buy a "jaw" puller to remove my harmonic balancer. I've been calling a bunch of places and no one seems to know what I'm talking about. Is there maybe a place online?
they only make 2 kinds. one looks like a claw (what i used) and one looks kinda like a birds foot. you will want to use the claw that has the 2 arms that pivot on and out with the screw in the middle. i bet autozone will loan you one.
Originally posted by grohl12
I tried autozone and they didn't know what I was talking about.
Holy sh*t, this is my 100th post!
I got my Balancer off with a Pry bar and a few hammer taps.
Granted probably not the best way to do it. But my Balancer seperated (inner part from the outter part).. So I just got it off the only way I could.
Originally posted by shoebox
AZ or any chain store should have a puller. This is what you want if you must use a puller.
Thanks shoebox, I will try AutoZone again. Now that I know it's an Ampro maybe they can find it in the computer. Thanks again!
YAY!!!!!!!!!!!! I FINALLY got that damn balancer off! I found the claw puller from the Autozone down the street. I called the guy on the phone and explained to him what I needed and when I got their he pulled out the same puller I had tried before. I thought it was hopeless but I spotted a picture of one the I needed on one of those little pads they have on the counter. Luckily it had a part number next to it.
I needed i bit more clearance for this puller so I removed the radiator fans and whammo! That sucker came off in just a few seconds! I'm so stoked! Thanks guys for a ll your help! I'll take some pictures and post them when I finish cuz I got a red powder coated Water pump and a CSI pump and if I can scrounge up some extra cash I want to get some braded steel hoses while I've already got everything taken apart! Havbe any of you used the hoses from Summit racing? Are they similar to the ones at Pep Boys or better? Thanks again everyone!
The correct leverage makes all the difference and you are right, it takes less than 30 seconds once you get it on there. It is a whole lot easier to have the right tool than to fight with it and break it or something else.
Originally posted by Mtrhds94Z
And hopefully you put the puller on as shown in shoebox' pic... [using the outer diameter can damage it..]
