harmonic balancer
Old May 23, 2017 | 10:18 PM
94Z28LS1toLT1's Avatar
harmonic balancer
Hey guys I noticed when i was running my engine my serpentine belt was like wobbly,so I took it off n noticed it's ripped a bit like at the end it,n peeled like a twizzler.
I noticed what caused it was the harmonic balancer is chipped n part of it has Sharp edges n that's why the belt is bad.
so I'm trying to get the balancer off so I can get a new one put on,n I'm having a hard time getting the part off,I'm using the harmonic balancer removal tool to get it off n no luck any better tools u guys know of
Old May 23, 2017 | 10:36 PM
gaedbo's Avatar
Re: harmonic balancer
I don't know if the 94 Z28 has the same pulley as the 95, but does it look like this in Shbox photo, if so maybe this will help.
http://shbox.com/1/pull_pulley.jpg
Old May 23, 2017 | 11:44 PM
Never mind I managed to get it off ok I'll need a different balancer, i was thinking about trying to get one from a wreck yard,or if you guys know where I can get one
Old May 23, 2017 | 11:46 PM
yes please that's the new part I need I got it off already just need to replace it
Old May 25, 2017 | 10:40 AM
Chimera96's Avatar
you can buy a new replacement Damper at most auto part store. Doorman likely the cheapest
Number: 594-017
You don't need to replace or remove the hub from the crank...just 3 bolts for the Damper
Old May 26, 2017 | 09:12 PM
Number: 594-017
thank u chimera that's exactly wat I did was the three bolts lol. Yea I nudge it off after the three bolts,i ended up finding one at a wreck yard in good condition for 6 dollars. I had an annoying squeak coming from belt,no more now.
Old May 28, 2017 | 04:17 PM
bw_hunter's Avatar
Usually there is a bit of rust built up on the hub...you should probably yank the balancer back off and clean the hub and the balancer. You'll get longer belt life that way....
Old Jun 3, 2017 | 04:40 PM
thank u bw hunter I did that to before putting the belt on,belts running smooth now and straight.
