Hardened Pushrods
Old Feb 11, 2007 | 02:36 AM
Jared 3870's Avatar
Hardened Pushrods
I have been looking into getting the Hotcam kit down the road, and have read that hardened pushrods are a good upgrade while I am in the motor. I read over at speeddensity.org that 93 through like 95 1/2 had hardened pushrods from the factory. Is this true? If it is true would it still be good to get some new ones for insurance?
On Thunder Racing's website ( http://www.thunderracing.com/catalog...vid=4&pcid=106 is the page I am referring to) I see a P/N for hardened pushrods that are 35 bucks, are those the ones i should be looking at (P/N 63-7808-16)? Or should I get the chromemoly ones?
Thanks.
Old Feb 11, 2007 | 03:17 AM
maro z28's Avatar
Look for 1 piece chromoly(SStrokerAce just told me that)
P.S. I'll be selling my hotcam kit(maybe minus the RRs) down the road when I upgrade as well. Only been in the car for about 2k miles(car has never been a dd-it's a creampuff-only 28.5k!) Summit sells the hotcam kit for $560. I could sell you mine for $225 w/out RRs, $250 with RRs. Just pm me when and if interested. Good luck!
Old Feb 11, 2007 | 03:23 AM
SS RRR's Avatar
Thanks.
For what you are doing it is not necessary for chromoly.
Old Feb 11, 2007 | 10:49 AM
SStrokerAce's Avatar
MAYBE.... but why put junk pushrods in a motor ever? It's like putting in a grade 8 bolt in a rod.
$35 pushrods are ok in very low spring pressure OEM applications. Even the stock LS1 valvetrain gets huge gains from stiffening up the spring to a LS6 spring and installing real pushrods. The motor will make more power and spin to 7000rpm without a hitch with those two changes. It's good for a mph or more at the track amazingly.
A OEM hardened pushrod is not up to the quality of a chromoly aftermarket piece, the wall thickness can be all over the place and the base metal is not as stiff.
Bret
Old Feb 11, 2007 | 12:01 PM
buzz12586's Avatar
So even on a cam only motor you would suggest spending the extra $100 and going with the chromemoly ones???
kline454's Avatar
I have the comp cam $35 push rods in my 383 with cc306, and 918 springs there are hardened and i have no problems.
Old Feb 11, 2007 | 12:18 PM
2000GTP's Avatar
It seems like there is alot of confusion involving what years exactly had the hardened pushrods. Considering the low cost, it just wouldn't hurt to buy a new set for 30 bucks. I don't see why hardened pushrods wouldn't be adequate for just a Hotcam?
Yep....USE THEM!!!! I don't care if someone hasn't had problems. Once you understand the physics of what is going on in there and see changes on the dyno where you "find" 40hp with pushrods you don't take them lightly after that.
Do a search and see if you can find the results of pushrod failures, that's the worst thing. The rest of the time the crap cheap ones are flexing in there like crazy giving you valve events that aren't even close to what the cam specs are.
The HotCam is pretty tame, but even so with increased spring loads and the rocker arm mulitpling the spring load more with higher ratio rockers that are also stiffer the pushrods become more and more important.
Then again don't listen to me, I only do this for a living.
Bret
Old Feb 11, 2007 | 12:22 PM
seawolf06's Avatar
Bret
Old Feb 11, 2007 | 12:25 PM
2000GTP's Avatar
Bret
I didn't realize that hardened pushrods had a hard time standing up to a tamer cam such as the Hotcam. Thanks for the clarification.
Old Feb 11, 2007 | 12:28 PM
mdacton's Avatar
my buddy had a 600+ cid musi motor and picked up 40+h.p. when he switched pushrods, hardened just means they are hardened, not any stronger than the stock pc.
Old Feb 11, 2007 | 12:43 PM
buzz12586's Avatar
Thanks for the clarification Bret. I'll be changing my list of parts and bumping up the total cost once again.
Old Feb 11, 2007 | 02:51 PM
Jared 3870's Avatar
Thanks for the advice Bret. I guess when I do this, I'll be spending the big bucks and doing it right. Currently I just want the motor to be streetable and reliable. I think the hotcam will give me the boost in power I want, without breaking the bank, and some chromoly pushrods will make it take the abuse of the increased spring pressures.
Old Feb 11, 2007 | 03:02 PM
SS RRR's Avatar
Bret
LMAO... JUNK? OEM hardened pushrods are not JUNK, Bret. As stated and as you followed up, for his application it is NOT NECESSARY to spend the extra money for chromoly. I ran OEM hardened in my LPE stuff for 70K miles and they looked brand new when I replaced them.
So now are you saying that if you get chromoly, w/ higher spring pressures and spin the motor well past that cam's power peak, the engine will make more power?
Please enlighten with this mojo! You still have yet to explain how Comp R retainers "act" on the plunger.
Old Feb 11, 2007 | 04:19 PM
kline454's Avatar
IM with (SS RRR) on this one! there is no need to put chromoly push rods in on a hot cam, or with 918 springs summits cheap push rods are good for 300+ spring pressure and the 918 spring are just over 300. i used stocker with 130k on my cc503 and ran great with no problems,
