hard starting after FPR and Injector install
Old Nov 30, 2004 | 10:03 PM
Heatmaker's Avatar
Advanced Member
After the car has set for a couple of hourse she stutters... badly... and then starts up like there's a crazy cam in there.... just installed some new injectors and an FPR.... Thanks to the FPR the furl pressure is where it should be... so it's not that? ...??? Injectors are Accel 24's I got by mistake...
Old Dec 1, 2004 | 09:54 PM
Guest47904's Avatar
Guest
Re: hard starting after FPR and Injector install
What's the fuel pressure doing after the engine is shut off? Do you still have stock fuel lines? If the pressure is dropping after the engine is shut down, try clamping the supply line. If it still drops down, you have a drippy injector. Seen lots of em drip from debris.
Old Dec 1, 2004 | 10:01 PM
Heatmaker's Avatar
Advanced Member
it holds.... then goes down slowly... after a while...
Noenav
Mar 1, 2019 07:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
