Hard start, messed up
Old May 10, 2006 | 09:30 PM
z71camaro's Avatar
This thing is driving me nuts. It started 2 weeks ago after driving it in the rain, then it sat for 2 days. It was hard to start and then backfired on me, then was fine. Once it dried up it ran fine for a week.
Then same thing, drive in the rain, sit for 2 days and hard to start again.
Then it started doing it all the time. At first after starting it would cough and sputter at about 200 RPM for 5 seconds then die, then start up fine.
But it was running pig rich and fouling plugs.
After 5 mins of idling, the long-term fuel trims were already at 108, so the PCM knows its running rich and trying to compensate.
Now when I try to start it, it tries to idle but its actually coughing back out the intake.
-Compression is 200 across the board.
-Fuel pressure is good and doesn't leak down. Also checked the injectors and FPR for leakage and nothing.
-All sensors scanned are reading within limits.
-Had opti off and it looks mint, not a hint of moisture or rust inside. Cap and rotor were a little worn but cleaned right up and didn't change a thing.
-Unhooked MAF and nothing changed.
-Plugs did nothing, wires all look in good shape, only 2 years old.
Its a 97, bolt on car, stock injectors.
Anybody have any ideas, it is greatly appreciated!
Old May 10, 2006 | 10:21 PM
NovaTodd's Avatar
Re: Hard start, messed up
Have you checked the opti harness? If the harness is corrorded, it could cause these problems
Old May 10, 2006 | 11:51 PM
z71camaro's Avatar
It looks mint.
Old May 11, 2006 | 07:12 PM
z71camaro's Avatar
Now it won't even really start. It just sputters and coughs at about 100 rpm and coughs back out the intake with each rotation.
Old May 11, 2006 | 09:21 PM
Evil Eric's Avatar
o2 sensors? you ever done anything to the rocker arms?
Old May 11, 2006 | 10:26 PM
z71camaro's Avatar
O2's are a year and a half old and reading fine. Besides it does it right from cold start.
Never touched the rockers, why?
Old May 13, 2006 | 12:39 AM
z71camaro's Avatar
Anybody have any ideas?
There has to be something I'm not thinking of.
Old May 13, 2006 | 06:21 AM
Guest47904's Avatar
Guest
I'll venture a guess to say ignition related and probably a global issue. By that I mean not individual plugs or wire but rather something that effects all the plugs such as coil wire, coil or ICM.
check the spark quality at a few random easily accessable plugs. If it's not what it should be, try a new coil and coil wire. Wouldn't hurt to look at the coil and wire at night while it's running either.
armedtrigger
Feb 24, 2015 08:30 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
