Halting Acceleration and Ticking Under Load
Old Oct 23, 2009 | 06:40 PM
aaron1987's Avatar
I've been having an intermittent problem with my Z lately. Aggressively throttling up when the engine is in gear at 2-3k rpms occasionally causes a loud ticking noise from the engine bay and very jerky, halting acceleration that is way underpowered. Shifting to neutral and flooring it will not exhibit any problems, and down shifting will cause it to mostly or completely dissipate. The higher the load the worse the problem. Any ideas?
Old Oct 24, 2009 | 11:19 PM
Venomous360's Avatar
what grade fuel you using?? Sounds like Spark knock to me. If you use 87 tru 93 and see if it changes. Other than that, sounds like its OPTI time.
Old Oct 25, 2009 | 12:54 PM
popstoy's Avatar
check all spark plug wires make sure there tight and have no breaks and make sure your plugs are tight in the head sounds like misfire to me.
Old Oct 26, 2009 | 05:21 PM
aaron1987's Avatar
Plugs were just replaced recently so I assume they should be fine but I'll check it out.
I was really hoping no one would come in here and say opti... so much for that
I think I may have filled up with 89 octane last time, I know I've done it before and not had problems but I'll fill it up with 91 (hard to find 93 here) and see if it makes a difference.
Old Oct 26, 2009 | 09:26 PM
The Untouchable's Avatar
put a scanner on it and read your map pressure
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
greenzee28
Sep 25, 2015 04:29 PM
CARiD
Sep 7, 2015 08:21 AM
