guys who have sumped the tank????
Old Dec 2, 2005 | 05:14 PM
1redTA's Avatar
i am fixing to sump the tank on my 96 TA with a CE sump and an A1000 pump blah blah blah you guys know the set up, but my question is how do you or what is the best way to route/run the return to or in the tank??? do you put a bulk head fitting in the top and let it dump?? what seems to work for you guys Thank In Advance ART
Old Dec 2, 2005 | 05:23 PM
1racerdude's Avatar
Re: guys who have sumped the tank????
We left the factory unit in minus the pump. I crimped and epoxied all the lines except the vent and the 3/8 output line. I then used the 3/8" line for the return. You can get fittings from metal tubing to a -6AN or whatever ya are using for a return.
blac94Z
29
Mar 25, 2015 04:21 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
blac94Z
Nov 24, 2014 07:12 PM
Red97LT1
Aug 7, 2002 05:45 PM
