Guys runnin 12's inside.
I'm on a quest as you once were,to hit the 12 spot.Here is my best time so far.My 60'time was 1.98,and my quarter was 13.33@103.7mph on BFG's.I want to get in the 12's without a TC or Cam cause I'm waiting to buy my rearend for those mods.I can't use LT's cause of emissions.I just need about 20-25 horsepower for that .3.Any advice would be nice.
1.6roller rockers and a set of LT4 springs will get you 10-15 hp. You'll get added lift, a tad more duration at .050 (because of the faster valve opening rate) and a tad more valve overlap. Basically it increases the lift "area under the curve."
Cutout dropped about 2 tenths for me, but I have a standard and can stand to lose some low end power because we have infinite stalls.
Don't move your powerband too far up in the rpms if you don't plan on having at least some stall. power in lt1s starts to really come on after 2000 rpms.
If you still have the stock torque converter get a 9/11 from PTS and you'll be there. And yeah lose some weight. I took over 1/2 second out of my car by losing 400lbs and it was free. The converter will really wake the car up. Here is a link:
http://www.ptsnctb.com/
Dave<--still on stock rear
A couple of things you can do....loss some wieght off the car(200# = .1) .....get your 60' down to 1.8 or less. Disconnect the front sway bar and get an air bag to help 60' time. You can also take the serpentine belt off at the track to free up a few ponies. Your biggest oppertunity is improveing 60'.
Originally posted by 93zder
What did you do to lose 400lbs??
http://pweb.jps.net/~tcssolutions/_u...MG0131crop.JPG
[B]He he. Actually my car is currently more than 500lbs light. I haven't weghed it lately but it was at 2920lbs before I removed most of the accessories and the air box. It is prolly under 2800lbs buy now. It is a drag car so I removed everything not needed for drag racing. Although not recent pics it should give you some idea. Don't laugh, it is going to be a single digit drag car someday.
Originally posted by gb95zconv
LOL....I cant belive you stripped out all of that and added that ugly ars dash mat.
