Guys with 383 Strokers...What TB are u using? 52mm or 58mm?
If you have stock heads and plan to keep stock heads stay with stock TB but if you are going to get heads go with a 58mm you will think me later. I have read about this many times and I found that to get the max out of a head cam package you should go with a 58mm. Say you put a 58mm on stock set-up or even just bolt ons you will get min. gains. Stroker motors with head and cam really show results from this mod.
The gains even from 52mm-58mm upgrades on stroked, cammed, and head show very pleasing results
will be on my 383
