guide plate question
Old Aug 19, 2004 | 08:34 AM
TransAmGT94's Avatar
I have a set of NSA 1.6 rockers. I know i need guide plates to run them.
I was told that to run them i would also need a longer rocker stud is this correct? If so which studs are most people using and which guide plates are suggested?
Thanks for all you help
Chris
Old Aug 19, 2004 | 08:49 AM
Re: guide plate question
Guideplates
GM p/n 14011051
Old Aug 19, 2004 | 09:18 AM
thanks for the pn for the guide plates. Is is true that i will need longer studs?
Old Aug 19, 2004 | 02:37 PM
sssalah's Avatar
Those are the same GM performance guide plates that I used, and I believe them to be the only dimensionally correct plates for LT1/4 applications.
I’ve used ARP 7/16 studs that have the same length as stock, so I don’t think you’ll need taller studs. Make sure that pushrods are hardened steel.
Old Aug 19, 2004 | 02:54 PM
Thanks alot guys im hoping thats all ill need to get my project under way
Old Aug 21, 2004 | 07:00 AM
arnie's Avatar
The only guide plates I find to accurately locate the rocker on the valve stem of LTx heads are adjustable plates.
Maybe, it's just me.
oldschool
Feb 9, 2016 09:21 PM
Newgmman
Feb 25, 2015 02:53 PM
alphaauto
Jan 23, 2015 07:42 AM
heavenly_six
Dec 10, 2014 12:23 AM
Brent94Z
Mar 21, 2002 04:44 PM
