guess my time w/ my mods
Rhino Racing Heads
Heads Ported + Valve Job
Recalibrated ECM
J&E Pistons
J&E File Fit Rings
Melling Oil Pump
Comp Cams Oversized Cam
Crane Valve Spring Kit
Crane Pushrods
Magnecore Wires
30 lb. Injectors
JBA Long Tube Headers
Crane 1.6 Rockers
52mm Edelbrock Throttle Body
New Starter Selanoid
Moroso Cold Air Induction Kit
3" Flowmaster Exhaust
No Catalytic Converters
car is a a4 1996 trans am lt1. 48k on engine. A rough guess would be nice.
Recalibrated ECM
J&E Pistons
J&E File Fit Rings
Melling Oil Pump
Crane Pushrods
Magnecore Wires
30 lb. Injectors
Crane 1.6 Rockers
I like my 3.42, no complaints. They came with the car. If I had to do it myself, I probably would have went with the 3.73 though. As far as your ET, I'd say the stock gears will hold you back.
cyteone
Feb 7, 2015 06:04 PM
