Ground Straps
Old Dec 23, 2005 | 10:09 AM
Dfetter84's Avatar
Ground Straps
Where do you put the ground straps and what are these for
Old Dec 23, 2005 | 10:24 AM
got8?'s Avatar
Re: Ground Straps
They are to prevent static electricity, put it on a known good ground like a bolt on the chassis. They are a must if you are dealing with electronic equipment like circut boards.
Old Dec 23, 2005 | 12:17 PM
OBE1 95Z28's Avatar
Re: Ground Straps
The engine block needs to be connected back to the battery ground in order for your ignition (spark plugs) to fire (complete the circuit). The ground straps connect the engine back to the frame/body panels that the battery ground ties to. The stock straps on the driver's side connects to a bolt in the front of the head just behind the coil.
Old Dec 23, 2005 | 12:45 PM
OBE1 95Z28's Avatar
Re: Ground Straps
Here's a photo of the ground strap on the passenger side thanks to Shoebox:
http://shbox.com/1/battery_cable_ground.jpg
95chwagon
Oct 16, 2015 12:24 PM
autoxr166
Sep 25, 2015 04:21 PM
Greg88
Sep 20, 2015 07:14 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
92_RS_305
Sep 8, 2015 07:47 PM
