Grinding sa tabs on pro mag rocker
Old May 27, 2005 | 05:40 PM
unTAmedLS1's Avatar
It it possible to just grind the tabs off of a sa rocker to make it non-sa. Heres what happened. A couple of my sa rocker tabs got chewed on about 3 or 4 rockers and i dont have the cash for a new set yet so i was thinking of just grinding em flat and using a guide plate for those rockers. Has anyone done this before? what would be the best way to grind it since the tabs are so close to the roller?
Old Jan 11, 2006 | 09:40 PM
c0rey's Avatar
Re: Grinding sa tabs on pro mag rocker
im also curious. Let me know if you tried it out.
Old Jan 11, 2006 | 11:04 PM
unTAmedLS1's Avatar
nah i just shelled out the cash for non sa ones...
Old Jan 12, 2006 | 04:10 PM
Walkersteelhead's Avatar
Besides the sa tabs what are the diffrence between the two.
Old Jan 12, 2006 | 04:30 PM
jsetzer's Avatar
I think the cup shape is different?
Old Jan 13, 2006 | 11:31 PM
c0rey's Avatar
Are you sure about that?
Old Jan 13, 2006 | 11:37 PM
Mean Green's Avatar
i believe the only difference is the aligning tabs. so in essence it should work.
HOWEVER, in my experience it's NEVER a good idea to mix and match parts. if only 2-3 of the rockers are bad, you can order invidual rockers. check summitracing.com or call the company directly.
Old Jan 13, 2006 | 11:40 PM
c0rey's Avatar
well i spent good money on these pro mags i wanna try grinding all the tabs and run them with lt4 guideplates, Ill let you guys know the outcome.
Wart Hog
Sep 8, 2015 05:53 AM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
Catmaigne
Jul 14, 2015 05:17 PM
Boss002
Jul 9, 2015 03:33 PM
