green vs red ! (coolant that is)
Old Jun 24, 2003 | 11:24 PM
tom3's Avatar
I just did a coolant change. I used to have the green stuff, but I realized the one I bought is dex-cool red; I flushed the whole thing and put the red in. I was wondering if I am the only one with the red stuff instead of the green one
Old Jun 24, 2003 | 11:28 PM
Rodrigues's Avatar
LMAO Other way around bud...
Old Jun 24, 2003 | 11:31 PM
Terran2k's Avatar
well my car came with dex-cool. when my water pump went out, the shop changed it to the green stuff. its been green ever since last year...I have some dexcool sittin in my house, soon as I get to it I'll change it back to dexcool.
Old Jun 24, 2003 | 11:50 PM
Z28Nut's Avatar
I run distilled water and a bottle of water wetter in the summer and when it comes time to put her up for the winter, she gets a 70/30 mix of the green stuff. Changing it at least twice a year, I don't need no stinkin' red stuff. She's a 94 and the inside of the radiator looks brand new -- no scale or gunk.
Old Jun 25, 2003 | 12:20 AM
fbird95's Avatar
You can run green gycerol i think they call it, in place of dexcool. But if you switch you will need to seriously flush the out the whole system to go back, cause the green eats dexcool. I like the green better. Thats what i run.
Old Jun 25, 2003 | 12:41 AM
Z28Nut's Avatar
Terran2k -- only use distilled water with Dexcool cause tap water will make it gunk up after a couple years. Also flush it completely like fbird95 said. After three years my 00 ZR2 Blazer had to be acid flushed to get the Dexcool gunk out of the heater core so it would work. I've heard the factory is too cheap to use distilled water when they fill them and cooling system flushing isn't covered by my GM extended warranty.
Old Jun 25, 2003 | 12:47 AM
CamaroRob97's Avatar
ive heard from a realiable source that GM is having some "issues" with dex-cool, and was told if the car was equip. originally with it to keep it in for about 2 years then switch over to green stuff...anybody else heard GM having problems with Dex-cool????
Old Jun 25, 2003 | 01:17 AM
Z28Nut's Avatar
My 00 Blazer clogged up the heater core with dexcool and the service manager mentioned something about a bulliten saying to acid flush the system. I had it done but haven't checked to see what they put back in -- red or green. Hmm. . .
Old Jun 25, 2003 | 12:48 PM
Acct 23749's Avatar
I have been running green for about two year now and my heater core popped.../
when i took the heater core out it was full of red lol......
I will NOT be using red any more.... Im a green guy and my perfectly clean radiator like green too
Old Jun 25, 2003 | 01:44 PM
tom3's Avatar
I flushed the system pretty well (water hose open in full in the radiator, bottom open and engine running). Tons of crap came out; I had the last coolant + water wetter in for 3 years.
Then I put the red stuff, but there is now green crap (small particles) floating in it!
looks like I need to flush again. Do you guys know any chemical I can use at home to flush the thing? (vinegar's pretty acidic; would that work? I can remove the thermostat, and run the electric water pump to get everything to flow)
Old Jun 25, 2003 | 02:11 PM
u can get all kinds of radiator flush, just be careful esspecially if ur like me and have an electric w/p cuz sometimes that stuff is feally strong and can eat way at ur gaskets and seals...
Old Jun 25, 2003 | 02:13 PM
Bralgar's Avatar
I was under the impression that DexCool (the red stuff) was for Aluminum headed vehicles.
Old Jun 25, 2003 | 02:16 PM
marktisch's Avatar
Be sure to flush your system well if you switch from one to the other.. Dex cool and the green mixed will accually "gum" up and then you'll have a mess on your hands. It does last longer than green but is much more corrosive.
Old Jun 26, 2003 | 12:42 AM
fbird95's Avatar
I have heard about GM having issues with dexcool, a buddy of mine had a problem with his 98 cutlass and dexcool. The dealer did the work (waranty) and told him green from now on.
blac94Z
Feb 15, 2021 09:43 PM
Feffman
Oct 9, 2015 05:42 AM
Feffman
Jul 2, 2015 06:52 AM
warmeck
Mar 1, 2015 08:47 PM
Collector Car
Dec 17, 2014 01:12 PM
