Great. Scanner cant connect to read. help
omg. just looked at your scan page myself with the jumpers.
(i had called my friend to verify where to put the jumpers)
apparently he dont know right from left... he told me the wrong damn side to jump... i knew pin 5 and 9 just didnt know where to put it on the cable... he made me go onto the left side and not the right. what a genius.
back to schucks i go
im still getting no reading. i use the obd1 cable and jumpered it like on your diagram. still nothing. im not sure whats really going on here. blaaaah stupid car. i love you but stupid car. im gonna call around and see if anyone else obd1 scans
and anyone suggest a scanner to use? do they normally have this problem? what scanner does everyone else use on their 94/95's? even better does anyone have a 94/95 that can goto schukers, kragen, oreilly.. whatever their kragen owned store is and try to see if their scanner will scan your car? im at a loss, shoebox says its probably not the PCM so that will be my last resort. i really need to get these codes scanned
I have an Auto Xray ez-scan 5000 that scans OBDI and II. It will scan a '95, as I've used it on some friends cars. However, it appears it is no longer available. The 6000 or 7000 will also do it.
If you have a laptop, there are other options.
www.autoxray.com/product_category.php?id=338
If you look around the web, you can find these cheaper than are listed on the site.
right on. i guess ill look into getting it for the laptop.. never a bad thing to have. and thanks for the offer! im up in vancouver, wa unfortunately.. little far
guess i should add my location, coulda sworn i had done that.
what cable should i get for use with datamaster or freescan? obd2 style from akm? and should i get usb or rs232.
laptop has windows vista... unfortunately.. will either cable matter?
You need the cable with the OBDII connector for a 95 Camaro or you could get the one that has both connectors if you want to use it on both 94 and 95 Camaros. I use the AKM usb cable with Vista and it works fine with Tunercats and Datamaster.
Nayr
Mar 3, 2023 08:34 PM
