Grease removal
Old Feb 24, 2005 | 09:27 PM
jcolez28's Avatar
Grease removal
I needed to get rid of the old thick build up on the bottom area of the engine bay. I never had much luck with the degreasers. What have you guys used with good results? Thanks
Old Feb 24, 2005 | 10:42 PM
Mean Green Z28's Avatar
Re: Grease removal
hmmm, I've never tried it but a lot of people I know have had quite a bit of luck with "Simple Green". I've seen engine bays after they've gone over it with that stuff and they looked CLEAN!
Old Feb 24, 2005 | 10:45 PM
Silvershark's Avatar
Re: Grease removal
Take it to a professional detailer. It should cost you about 60 bucks for them to degrease the engine for you. Just make sure you specify what you want done.
There is a place here that will detail the inside and outside of your car as well as degrease the engine for around $180.
Old Feb 24, 2005 | 10:53 PM
jcolez28's Avatar
Re: Grease removal
The intake, h2o pump, alt, and bracket are off getting powder coated. I dont mind doing it myself but I wondered if anyone had found a good cleaner for the years of caked on performance by products. Thanks
Old Feb 25, 2005 | 11:29 AM
Re: Grease removal
Depends how thick the grease is really... I drove my car over that tar crap right before they lay asfault down, and that was like underbody coating. I had to use a halogen shop lamp, a putty knife and a rag. I wrapped the rag around the putty knife so I didnt scrape anything and let the light warm up the tar, I was then able to remove the tar off and then take simple green and kapow and clean off all of the rest of the grease/oil that was left. Since my engine was removed from the car I used simple green and elbow grease and it all came off. However, this process took me atleast a week with 3-4 hours a day. But I am **** and the underbody looks like it did when it came off the showroom floor, minus the scratches and what not.
Old Feb 25, 2005 | 02:11 PM
1 Nasty Bird's Avatar
Re: Grease removal
I bought 1 can each of the degreaser sprays and tryed em each out. Most did nothing but one just absolutely ate through it like it was nothing. It was either a white can of gunk brand degreaser, or a black can that said "steam" real big in like chrome letters, the more i think about it the more i wanna say it was the black "steam" can. It fizzed up and kinda foamed and the grease literally ran off the parts i was cleaning. Stuff was great got it at autozone.
Old Feb 25, 2005 | 09:53 PM
jcolez28's Avatar
Re: Grease removal
Thats sounds like a nightmare cleaning that tar off. Tar is wicked for sure. Ill go to the Zone and pick up a can of the chrome stream. I think I tried the gunk and was disappointed before too. Ill let you guys know , thanks
Old Feb 25, 2005 | 10:00 PM
Re: Grease removal
Ya i would gt 1 can and try it out, i bought one of each can on the shelf to do a lil experiment and all but 1 did absolotely NOTHING, but i beleive the steam was the one that just lifted the junk right off before even thouching it, i mean thick greasy black shmootz was dripping off the motor before i even took a brush to it. I was like Ill never use anything else again. Lemme know how it worked for you.
Old Feb 25, 2005 | 10:04 PM
Todds355TAGT's Avatar
Re: Grease removal
PURPLE STUFF!!
if you use it very concentrated, it is industrial strength.
Put it in a pump up sprayer at a local carwash, soak everything!
sit for 15 min, them power spray it.
works like a dream.
PS
I did this to my jeep 4.0 before I did the rear main seal
ToDDR.
get the purple stuff @ depot or any place that sells some sort of industrial degreaser
Old Feb 25, 2005 | 10:40 PM
jcolez28's Avatar
Re: Grease removal
Is Purple Tuff the actual name? Or its purple and you cant remember the name. Ill try it too. I use Wesleys bleach white faithfully on tires, interior, wheels, ect. It is a dream cleaner and you can still use it in the bathroom!
Old Feb 25, 2005 | 11:07 PM
Re: Grease removal
Originally Posted by jcolez28
Is Purple STuff the actual name? Or its purple and you cant remember the name. !
my memory is **** but just look, Yes It is Purple, the generic name is purple stuff, A few mfr's make it. I think Castrol makes it in a purple bottle, you just want a commercial/industrial strength degreaser!
ToDDR
http://store1.yimg.com/I/superkleendirect_1829_1433327
sumthin like that!
holla
LET IT SOAK
dont be scurred to hose it down
TR
Old Feb 28, 2005 | 09:07 PM
jcolez28's Avatar
Re: Grease removal
Hey guys just to let you know I found the only grease cleaner. Its brake cleaner! I tried all the stuff and on another post someone reccommended it. I went and compared them and the 99 cent a can had the same chemicals so I got that and it ate the grease off like iwas blowing dry sand. It is a miracle! Just dont get in in your eyes or on your paint. And wear rubber gloves. Thanks.
Old Feb 28, 2005 | 11:43 PM
Munson's Avatar
Re: Grease removal
badass i was about to ask about this degreaser stuff on the paint.. i guess its all bad for it. what about the paint in your damn engine bay?
Old Mar 1, 2005 | 12:59 AM
Re: Grease removal
Yah, I personally like to use oil with a rag and it removes the grease like you wouldnt believe, but then you have to use brake cleaner to remove the oil film. But its a real quick process and not much elbow grease needed.
greenzee28
Sep 25, 2015 04:29 PM
wbspoon
Sep 19, 2015 08:12 AM
marlar98
Sep 19, 2015 07:53 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
