Got My LE3 1/4 miles time
Old Apr 4, 2007 | 09:38 PM
silverz28's Avatar
Finally went to the track. Here is what I ran:
60' ... 1.96
1/8 ... 7.85
mph ... 91.63
1/4 ... 12.126
mph ... 116.08
Ran it all natural. I havn't hook the NX system back up yet. I was fairly happy since I only got one run in and really couldn't hook. I have Nitto 315/35 's out back at 20psi but still no real traction. I was getting 1.7 60' times with my old hot cam. Remember, I dynoed at 402 rear wheel and 425 rear torque through my automatic with 2800 stall. With that mph, what should I be running with ideal conditions and traction? I just took delivery of some Pacesetter longtubes and I can't wait to put them on. That should help out a little since right now I have Mac mids.
Old Apr 4, 2007 | 09:44 PM
zx1216's Avatar
mph seams a little low maybe, post the conditions and altitude
Old Apr 4, 2007 | 09:49 PM
silverz28's Avatar
I think once I get the long tubes on, the mph will go up a little. Oh, this is through a cutout.
altitude: 10 ft above sea level
Temp: 70 degrees F
Hum: High (Houston)
Old Apr 4, 2007 | 10:02 PM
AutoRoc's Avatar
Sounds like 11.80's if it would have went 1.75'ish in the 60'. I'm sure it has a lot left in it. Play with the shiftpoint and see what it likes. More tire and converter could really make things come alive if you want deep 11's.
Old Apr 4, 2007 | 10:04 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
How stock is your intake out of curiosity?
Old Apr 4, 2007 | 10:11 PM
silverz28's Avatar
I ported the throttle body inlet on the intake to 58mm for my BBK 58mm TB. Lloyd port matched my intake for the heads.
Old Apr 5, 2007 | 02:15 AM
Joe B's Avatar
Not a LE fully ported intake?...just port matched, and opened for a 58mm TB?.........if so, there's another couple MPH in that alone(that's what mine picked up anyway)........the longtubes will probably give you another couple MPH......PS: If you were unaware, make sure to match your new header flange(ports) to your heads exhaust port.......very commonly after Lloyd raises the exhaust port where it needs to be, the upper 1/8th - 1/4 inch of your header port flange will be like a brick wall for the exiting exhaust flow......not at all good for max power.............good luck with it...........Joe
Old Apr 5, 2007 | 05:41 AM
big dave's Avatar
with the kind of power you're making, I would expect sub 11.5 times. I think you may have a couple minor bugs to work out but, for the most part, it didn't sound like a bad first day at all. As stated already, the mph should, and will go up once it all comes together. Good luck.
Old Apr 8, 2007 | 01:08 PM
sn8ke eatr's Avatar
a bigger converter would probbaly help. guys are running 3200's on basically stock cars with good results
Old Apr 8, 2007 | 02:44 PM
CamaroRacing12's Avatar
yes def a larger converter...i plan to put a 3200 in my near stock LT1.... ur puttin 400+rwhp out... atleast a 3600 or 4000 stall would wake that thing up
Old Apr 8, 2007 | 03:03 PM
2000GTP's Avatar
Your times aren't bad at all. I would talk to Lloyd though and see what he recommends in terms of gears and stall. I'm sure you still have some more left in your combo.
Old Apr 8, 2007 | 03:06 PM
SS RRR's Avatar
Most definitely. 2800 is no bueno once your torque curve characteristics change when adding something like cylinder heads.
HRP is one of the best tracks to gage how a setup will run when comparing mph to rwhp.
Old Apr 8, 2007 | 05:47 PM
neil350's Avatar
Long tubes would also pick the car up a lot, nice car though, looks real clean
Old Apr 8, 2007 | 05:56 PM
reamo04's Avatar
for a 383 w/ LE3 heads/cam, he recommended:
yank ss3600 stall
3.73 gears
26" tires
i already had that convo with him
Old Apr 8, 2007 | 06:44 PM
SS RRR's Avatar
Not necessarily.
