Got my headers today...
Old Apr 5, 2005 | 12:20 PM
blind527's Avatar
They look sweet! I'll be getting Breslin locking header bolts as well. I got scammed out of 300 dollars so I don't have money for a y pipe anymore. I'll probably be able to get the o2 bunges though. The only thing that is weird to me is on the drivers side header it has the tube that is off that I put in. It doesn't seem to mount straight with the rest. Should I also look into getting metal gaskets or are the stock ones fine?
Old Apr 5, 2005 | 01:05 PM
MeanGreen97Z's Avatar
Re: Got my headers today...
Who scammed you and where does he live? Maybe someone in his area could pay him a visit.
Old Apr 5, 2005 | 01:14 PM
blind527's Avatar
I guess they live in Lebanon, it's under investigation right now with the FBI, the postal investigation etc., I'm not even covered by Paypal either
Old Apr 5, 2005 | 01:53 PM
Kataklysm's Avatar
Use fel-pro gaskets if a set didn't come with the headers, copper gaskets leak.
Old Apr 5, 2005 | 01:57 PM
blind527's Avatar
What do fel-pro gaskets look like? My headers came with gaskets, but I'm not sure if they are any good. Should I get a 12 or 16 bolt set of Breslins? I think I'm just going to use the 6 nuts and bolts for where the y pipe meets. Do I just get 3" Fel-Pro collector gaskets? What about the bottom of the headers where it has those curved parts? It comes with those gaskets but should I get new ones?
Old Apr 5, 2005 | 02:41 PM
NBred94's Avatar
Fel-Pro is a gasket manufacturer (i.e. it's a brand name, not the generics that came with your headers). The only way I know to identify them is to look on the package. I got mine from Thunder Racing when I installed my MAC's.
As for your header bolts, you only need 12, but it never hurts to have extras.
And to answer your original question, the primary tube on the #1 (driver's side front) cylinder is a slip-fit design. they build them that way to get the primaries around the steering linkage. Just make sure that you tighten the clamp around the primary where it joins up with the collector after you tighten the bolts into the heads, and everything shouldline up, unless it it seriously bent.
Good luck.
Old Apr 5, 2005 | 02:52 PM
blind527's Avatar
So I will need Fel Pro LT1 D-port gaskets and Fel Pro 3" collector gaskets? What do I clamp down the primary tube?
Old Apr 5, 2005 | 02:56 PM
sszapper's Avatar
Also it wouldn't hurt to get some OTVC wires.
Old Apr 5, 2005 | 02:58 PM
blind527's Avatar
What are those? Can you link me?
Old Apr 5, 2005 | 03:38 PM
NBred94's Avatar
I'm not sure about the collector gakets, someone with longtubes will have to chime in on that one, but the D-port gaskets arer the ones you need. My MAC's came with a round metal clamp that fit around the outside of the slip fit connection, I'm not sure what the setup is on the Jet-Hot LT's.
OTVC = Over The Valve Cover
here's a link Thunder Racing
Old Apr 5, 2005 | 03:43 PM
blind527's Avatar
Ah, thanks a ton man, helped a lot!
Old Apr 5, 2005 | 04:48 PM
blind527's Avatar
How many o2 bunges will I need, 1 or 2?
Old Apr 5, 2005 | 04:56 PM
Doing any trading overseas is almost always a bad idea.
Old Apr 5, 2005 | 04:57 PM
blind527's Avatar
Yeah I found that out the hard way. Even though I have traded overseas numerous times with some people I know from other forums, you're always dodging the bullets.
Old Apr 5, 2005 | 06:25 PM
blind527's Avatar
What do I clamp the primary tube with?
