Got motor put together tonight. Have BIG problem
So tonight i finally got my motor back together. When i was filling the cooling system, water started to come out the back of the passenger side head. When i installed the crossover line i know the bolt threaded in properly when i started it. But it must have a bad thread in the head that caused the bolt to not want to install straight. So i was wondering if i can not easily fix this if i could put a plug in the back of the heads and make a crossover line for the front of the motor? This would save me from having to remove the heads.
Re: Got motor put together tonight. Have BIG problem
i feel like the accessory bracket would be in your way on the passenger side...
did you use the proper GM rubber washers? auto parts store oil plug washers will not work. a bad thread shouldn't matter as long as the bolt is straight and flush, it's all about those washers and getting the bolt torqued to 30 ft/lbs ish
I have seen people replace the rear bracket with custom AN lines, so that isn't an issue. I do not however know if that would impact cooling.
A better question to answer though, is if the head is gacked enough that the steam pipe won't seal, why would a plug?
you need 2 seals per steam pipe side. One on each side of the steam pipe where the bolt goes through into the head
if the threads in the head got FU...going to have to re-tap
93redlt1
Jun 30, 2005 05:07 PM
CoUnTryMuZiCZ28
Nov 24, 2004 08:33 AM
thewinner
Jul 7, 2003 09:23 PM
DarthIROC
3rd Gen / L98 Engine Tech
May 28, 2003 09:07 PM
