Got low oil pressure? I got the solution!!!!
Ever since I got the car i've been getting low oil pressure, maxing out at 40 psi no matter how high I revved. Today I was trying to fix a leak at the oil filter adapter so I removed the oil cooler, NOW IM GETTING ALL MY OIL PRESSURE I SHOULD BE GETTING! Find of the century if you ask me!
REMOVE THAT ****ING OIL COOLER!!!!!!
If you dont have lower oil pressure then leave it, I agree. What happens is stuff gets clogged in the oil cooler over time acting as its own oil filter and it blocks your oil...
Originally posted by Johnnynsac
Mine works great. I'll wait
Originally posted by AENIMA95z28
yeah, im not quite sure what it looks like
its below the drivers side exhuast manifold. cant miss the damn thing.
I hear it causes a lot of problems and its more of a curse than a blessing
Thats nothing new
I pulled mine off awhile ago and picked up about 10 psi. The cooler will actually act like a bypass to the filter once it gets a little dirty.
Once the cooler is pulled, you can also run a filter which is about 2x as big.
I pulled mine off awhile ago and picked up about 10 psi. The cooler will actually act like a bypass to the filter once it gets a little dirty.Once the cooler is pulled, you can also run a filter which is about 2x as big.
Jul 4, 2005 05:00 PM
