Got 32 code, replaced EGR valve, still get the same code?
Old Jul 16, 2003 | 04:55 PM
alex-z28's Avatar
I get 32 code on highway only, the EGR failure. So I replaced the EGR valve car ran great in city and on highway no engine light came on. It was like that for 3 days then I go on the highway again and I get the same code. What should I do now?
Old Jul 16, 2003 | 05:35 PM
sabre81's Avatar
did you clear the codes? if so than its probably a bad egr solenoid.
to clear codes you i used my laptop and freescan. Or you can disconnect the neg battery cable for like 10 min.
Old Jul 16, 2003 | 09:09 PM
Walkovaya's Avatar
have you removed your
cats?
after removing my cats i get the egr code occasionaly even after i replaced the egr.
Old Jul 16, 2003 | 11:54 PM
alex-z28's Avatar
I disconnected the negative battery terminal for like 2 days, also I don't have cats. Is it OK to drive it on the highway with engine light on, assuming that it sets off EGR code.
Old Jul 17, 2003 | 02:28 AM
revtime's Avatar
If your sure its the EGR code I would not worry about it.
I completely removed my EGR and blocked everything off, no codes and runs fine.
I would get it fixed as soon as you can but I don,t think it will hurt anything to drive it.
If you removed the cats I would block off the EGR and get rid of the AIR pump.
Old Jul 17, 2003 | 02:15 PM
sabre81's Avatar
yeah wont hurt anything except gas mileage. Did you check all the tubing to and from the egr valve? I just bought some new tubing for like a dollar and replaced it all. Also did you make sure you plugged the electrical connector back into the solenoid?. And LAST but not least if you removed the vaccuum tubing from the solenoid, did you reinstall it correctly?
should be like this diagram
Old Jul 17, 2003 | 03:31 PM
alex-z28's Avatar
I will check all the hoses and the connections but some how I don't think that's the problem?
Old Jul 17, 2003 | 06:20 PM
sabre81's Avatar
if their clogged with carbon it will throw a code. Also just wondering.. did you clean the port on the engine before you instaklled the valve and make sure there were no carbon deposits inside the whole? If all else fails you will probably need a new solenoid.
Old Jul 17, 2003 | 09:54 PM
Bandit97's Avatar
the guys at speedteck in hurst, (ft worth area) told me that if you replace the egr you could still get the same codes even with a new egr valve. They recomend deleting the egr completely.
grabbem88
Feb 13, 2015 03:09 PM
jocamino
Dec 29, 2014 10:15 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
