Is this a good oil pump setup / right parts?
Old Jun 16, 2007 | 09:30 AM
2QUIK6's Avatar
Plan on changing my 100k mile pump when I have it apart for cam swap.
I've read the threads on the new design Melling pumps which have been breaking and Melling recommends their "select" pumps for high performance applications.
So I'm thinking of getting the select Melling 10554 pump (std vol/std pressure)
Getting the GM white spring 3848911 to put in it for higher pressure
And then getting a new GM pickup tube, 12550042
Will all of those parts work together and is that a good proven combo?
Old Jun 16, 2007 | 02:49 PM
seawolf06's Avatar
Yep, that will work. Most people tac weld the pickup on as well, just for added insurance.
Old Jun 16, 2007 | 09:04 PM
FlamingChicken's Avatar
just out of curiousity, how come nobody buys the stock pump? discontinued or price prohibitive?
Old Jun 16, 2007 | 09:17 PM
wrd1972's Avatar
I am running the Melling select 10554 w/ the GM white spring. I have 30-40 PSI at idle and 60-70 PSI at WOT. I brazed the stock pickup on tight.
Great combo in my HP.
Old Jun 17, 2007 | 12:57 PM
2QUIK6's Avatar
Melling redesigned it supposedly at the request of GM, it has much thinner supports and it not recommended for higher performance motors, people have been breaking them due to motor vibration.
Here's a pic I found comparing the stocker M55 to the "Select" pumps
Old Jun 17, 2007 | 12:58 PM
2QUIK6's Avatar
Great thanks, I will tack weld the tube on as well.
Old Sep 21, 2008 | 05:07 AM
88IROC_Z's Avatar
what are the differences in the Melling select 10554, the M55, and the M155???
I already have a M155 can i use this and just use the M155 instead of the 10554 with the same components as listed?
Old Sep 21, 2008 | 09:14 AM
Look at the pic posted above.
Old Sep 21, 2008 | 10:37 AM
JoeliusZ28's Avatar
i have very good oil pressure with just the white spring - at 650 RPM hot its just under 20. Driving around it stays between 35 and 50, and WOT hits 60. cold motor will hit 70 sometimes.
I wish i would have known about welding the pickup tube while i was in there though...
Old Sep 21, 2008 | 10:58 AM
88IROC_Z's Avatar
soory, i did see the picture, i should have been a little more specific to what I am doin,
Ok, well as of right now I am building a "temporary" engine for my car it will be basically stock other than a a CC306 and car has bolt-ons in sig, my new engine should be ready next spring(budget permitting), and I am pretty much just doing new rings, rod b., main b., cam bushings and I already have a M155, instead of spending the $8X.XX on the select can i safely use the M155 with new white spring and new tacked on pickup?
I know the 10554's casting is stronger, but I am doing this rebuild on a shoe string budget as to not take away from funding from my other build and I need a dependable motor in the car right now since it is my daily driver...
... and thanks for all the help in advance and for all ya'll have helped with already!
Old Sep 21, 2008 | 11:26 AM
MTBSully's Avatar
sounds like your all set. as long as your going with std vlm and pressure you should be good to go
Old Sep 21, 2008 | 11:34 AM
You'll be ok.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
4586
Dec 31, 2014 02:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
