GOING STROKER!! 393 CI What should I upgrade on the car?
Old Mar 20, 2006 | 09:54 PM
Mike96z's Avatar
I have the engine ready, what will I need to upgrade before putting the beast in. I know I need fuel pump, wires, plugs, injectors, a badass tune, LCA's, a better torque arm, but what brands etc do you guys recommend. Thanks.
*Engine is fully modified ported and polished. Stock valve sizes.
Old Mar 20, 2006 | 09:55 PM
Mike96z's Avatar
Re: GOING STROKER!! 393 CI What should I upgrade on the car?
This is a 4.060 bore engine with the 3.750 crank and a 5.7" rod.
Old Mar 20, 2006 | 10:10 PM
Brettinator's Avatar
I just bought a BMR Trak-Pak, talked to their tech last Tue who gave me the skinny on the differences between it and the Extreme Tq Arm. I'm not going to be in 8's for a while unless I go nitrous which I have no interest to at this point on the new build.
Kind of depends too on what your goals are. I mean you'll want a good clutch setup, consider doing your T56 or Auto (built), upgrade the driveshaft, mine will be done tomorrow and I'll post you some pics/specs, rearend will need to be upgraded if your planning 4k launches on drag tires.....
post your goals
Old Mar 21, 2006 | 07:07 AM
97FormulaWS-6's Avatar
I'm in process of doing a VRE 396/LE TFR heads and the following is my mods:
Strange 12-Bolt, 3.73 gears
BMR Trac-Pack
Custom rod-ended rear-suspension
Denny's Nitrous Ready DS
Cryogenically treated Viperized T56
McLoud Twin-Disk Clutch
Aeromotive custom fuel system
Wolfe 6-pt weld-in
Simpson Harnesses
NX 200HP wet-kit
AS&M TB
Hooker LTs
Custom True-Duals
MT DRs/Nitto Fronts
deadmanrunning
Jan 3, 2015 01:12 PM
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
