Going to be pulling heads, any tips, tricks, or ideas?
Old Jun 9, 2003 | 01:50 PM
Hotwire's Avatar
changed water pump and opti, still had miss, filled up rad to do flush, kept on filling, when topped off, bubbles from return line, then water would sink to a point and stop. noticed a little oil in the water pump when i pulled thermostat. think i had a lean condition when taching the motor high in third and popped the gasket, going to do compression and rad pressure test tonight.
The motor is a 94 LT1/4L60e w/ approx 70k and is in a 89 s-10 with room to move, are there any tricks i need to watch out for when pulling the intake and heads, or is it all straight forward. already got screwed on the water pump coupling, thanks gm.
Hopefully will be recieving service manuals this weekend.
I am wanting to keep everything stock and get some baselines before I get my hands in it too far, but was wondering if any of you recommend any changes to do now that would be a PIA later on. I was thinking of lightly decking the heads and thinner head gaskets to start off..
Thanks for the replies ,
Jeff
Old Jun 9, 2003 | 01:53 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
strong tools
i broke my crapy ones.
get a fuel line disconnect tool, remove intake manifold and the valve covers and then heads...
maybe valve covers first.
and some mechanix gloves
Chris Anderson
Jan 27, 2015 08:30 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
