going to do head gaskets
Old Mar 20, 2005 | 08:58 AM
enzo1267's Avatar
I am about to do my head gaskets and need to know what are the best gaskets avialble or should i use stock gasket set, i dont beat on my car or anything like that. also how hard is this procedure on the lt1? thanks.
Enzo
Old Mar 20, 2005 | 11:09 AM
enzo1267's Avatar
Re: going to do head gaskets
also how bad is it to do only one head gasket and not the other...i was ADVISED to do only the blown gasket. (Which is the passenger side)
thanks
Old Mar 20, 2005 | 11:41 AM
Valkyn71's Avatar
Would be easier to just do the one, but while you have everything off it would only take about an hour more to do both.
Felpros are probebly as good as any, and you will probebly want stock thickness.
Any auto parts store can hook you up.
Old Mar 20, 2005 | 12:18 PM
94zgreenmachine's Avatar
I used fel-pro 1074 gaskets thru summit. I think I paid about 60 for the pair. Are you going to have the heads milled? Check them to make sure they are not warped, otherwise you may be doing it again. It wouldn't hurt to have a machine shop look at them for what little they should charge.
Old Mar 20, 2005 | 02:39 PM
enzo1267's Avatar
finding a good machine shop that does car parts isnt going to well for me in brooklyn ny , does anyone know of a machine shop in brooklyn or the surrounding area?
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
