Are the GMPP Fast Burns heads better the LT4 Heads?
Old Aug 27, 2009 | 09:27 AM
B'klyn9C1's Avatar
Guys,
I read in the Sept. 2009 issue Chevy High Performance, in the Q&A section, that the current Fast Burn heads from GMPP are really an as cast version of the CNC-ported LT4 cylinder heads.
So much better are the Fast Burns to the LT4?
Do you think that they would be a good part of a LT1/LT4 build after a conversion to reverse cooling??
Old Aug 27, 2009 | 09:31 AM
Guest47904's Avatar
Guest
Conversion is unlikely. Certainly not economical.
What they are probably referring to is the chamber design. Since the LT's invented the chamber design that was later called the Vortec and the Fast burn has the same chamber as those.
MattFick
Feb 15, 2015 10:16 PM
thenewkid
Nov 27, 2014 09:41 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
