GMPP 1.6 RRs Break?
Old Jan 1, 2004 | 07:01 PM
JONEZ_Z's Avatar
GMPP 1.6 RRs Break?
I just ordered some GMPP rockers off of ebay. I have been reading somethings about aluminum RRs that is worring me now. I have read that they break sometimes. I was wondering if anyone has had this problem with any aluminum RRs? Another question i have is , I have springs from tpis and they are good for .540 lift. but with the RRs my lift will be .515/.555. I was wondering if I could get by with using these springs. If i cant, were do i get some good high lift springs for a good price? Thanks
Old Jan 1, 2004 | 07:30 PM
RE AND CHERYL's Avatar
Cool
While aluminum Roller rockers are not as strong as crome molly they are just fine for motors with stock to moderate pressure springs. I ran a set of Summit Racing Roller rockers on a SB 406 with Sportman II headds for more than 30k with no problems. I beleive the Aluminum Rocker strength issue is more a result of efective advertising, as I have not seen but a few of these rockers broken. Most of which in vehicles with high pressure vavle springs that were being run hard.
I would not run those springs with that much lift with out measuring for coil bind at maximum lift. If you run the springs at too high a lift you will fatigue the springs if your lucky and break them if your not.
Old Jan 1, 2004 | 07:54 PM
engineermike's Avatar
All non-ferrous (iron-based) metals in cyclic service will eventually fail. Therefore, all aluminum rocker arms will eventually fail.
How soon? In dirt track cars running 250 lb seat pressure, they only make a few races. In a stock LT4 'Vette with 100 lb seat pressure, they'll go a couple hundred thousand miles. Pretty much everything else falls in the middle.
I'm using Comp Pro Magnums.
Mike
Old Jan 2, 2004 | 04:26 PM
JONEZ_Z's Avatar
So where can i get some springs that will handle the extra lift? Thanks
Old Jan 2, 2004 | 04:30 PM
Heatmaker's Avatar
Advanced Member
what are the Crane Golds made out of?
Old Jan 2, 2004 | 04:40 PM
simple's Avatar
i think those are 1 in the same as the GMPP rr's!
Old Jan 2, 2004 | 04:45 PM
93Z286Speed's Avatar
yeah, you deff dont wanna bottom out your springs. thats askin for a bent pushrod
Old Jan 2, 2004 | 04:57 PM
Aluminum.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Bxlt1
Sep 29, 2015 03:18 PM
