GM847 Setup ?'s
Old Apr 2, 2008 | 08:43 PM
MadMike 97 Z28's Avatar
GM847 Setup ?'s
well i kinda posted about this about a week ago but i need some more ?'s answered.
ok so the stock 561 heads will be shaved to help seal up better (blown head gasket is the cause of this whole project) when doing my cam swap i know its just insurance to repalce the timing chain and gear set, but im not entirely sure if mine wasn't recently repalced before i bought the car. so how critical is it to replace it or is it more of a peice of mind thing? should i run LS7 lifters or stock replacements? will i be running stock length pushrods or will i need a different size? should i go ahead and get guide plates? and if i stick with 1.5 rockers is it ok to run the stock stamped ones and if it is can i use poly locks on top of the bearings with out valve cover clearance problems? what valve springs are best to run? i really don't want to skimp on the springs so i will spend top dollar if necesarry on them.
also if you are running a gm847 or similar cam please share your setups what has worked what hasn't maybe this will help others that have the same questions i do.
Old Apr 2, 2008 | 08:52 PM
dangalla's Avatar
i would not run stock rockers with that cam
if your lifters are ok then there is no reason to replace them
just get a stock replacement timming set from gm
if you have the extra money it would be a good idea to go with non self aligning rockers and 7/16 studs, requiring you to purchase studs, guideplates, and chromolly pushrods, trick flow has cheap guidplates and chromolly pushrods for cheap
with the heads being milled, and you should also run a impalla head gasket which is slightly smaller to bump compression a bit, you will mostlikely need a smaller pushrod but you will need to check to be sure
as far as valve covers you will need to do a simple ten minute modification located here
http://www.golenengineservice.com/ht...html#valvecmod
Old Apr 2, 2008 | 10:33 PM
is the valve cover mod for clerance of the actual rocker body or the top of the poly locks?
Old Apr 2, 2008 | 10:47 PM
dangalla's Avatar
i think it is to clear the rockers but i am not sure, why do you ask?
Old Apr 2, 2008 | 10:58 PM
just trying to learn new stuff.
Old Apr 3, 2008 | 12:13 PM
97SS0594's Avatar
im running comp pushrods, the GM847 and comp 1.6RR with the comp R lifters, the comp guideplates are rubbing so im switching to the ISKY guide plated.
Old Apr 3, 2008 | 01:46 PM
good info thanks. i may get those guide plates aswell
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
