GM vs Comp Cams Guideplates (pic)
Old May 28, 2004 | 09:16 PM
PoorMan's Avatar
After the suggestions about my pushrods, I ordered the GM guidplates. There is a about a +0.040 or so difference in width. No much, but enough to rub into my pushrods pretty bad. Look at how the Comp Cam plates concaved after a couple of hundred miles.
http://community.webshots.com/photo/...47075942zoPQSe
Old May 28, 2004 | 10:19 PM
WS6T3RROR's Avatar
if i remember rightly the gmpp are supposed to be .050 different than the comps. i think the only other company that has good guide plates is isky. what i remember is the lt1 is supposed to have the valves spaced .050 different than a standard sbc.
Old May 29, 2004 | 02:02 AM
texasTA's Avatar
So are you basically saying that the Comp Cams guideplates are crap?
Old May 29, 2004 | 02:08 AM
WS6T3RROR's Avatar
no they're not crap just not right for the application. but I do personally prefer gm.
Old May 29, 2004 | 05:49 AM
jkipp84's Avatar
Strange... I've been running Comp guide plates for 2 years now, no problems. I just pulled my heads last weekend and the pushrods were in great shape, same for the plates.
I'm using Comp 1.6 Pro Mags, Comp hardened pushrods, and Comp plates.
Old May 29, 2004 | 06:22 AM
texasTA's Avatar
Are you running the 3/8 rocker stud or 7/16 rocker studs?
Old May 29, 2004 | 06:30 AM
jkipp84's Avatar
7/16" Comp studs
Old May 29, 2004 | 07:52 AM
NightTrain66's Avatar
I have looked at Crane, Comp, etc. guide plates on LT1's before and the rockers sit off to the side of the valve a little bit. The minor HP loss is not the big problem but this is not good for guide wear. The GM # 14011051 guide plates allow the rocker to sit centered on the valve and push strait down on the valve.
There are a few posts on this sight about this if you do a search.
According to Comp, Crane, Manley, etc, they show the same part # for the LT1 AND allof the other SB Chevys. As mentioned, the aluminum LT1 has a slightly different valve spacing and needs a lil different guide plate. The Comp guide plates are good quality but the problem seems to be that they have not addressed the fact that the LT1's are different.
I would not expect the pushrods to be chewed up regardless of using a GM or Comp guide plate. Are your pushrods "hardened" or just "chrome moly"?
Lloyd
NightTrain66@msn.com
Old May 29, 2004 | 11:40 AM
PoorMan's Avatar
They are the stock 94 pushrods. Btw, Thanks Llyod for the reply to my email about the heads you did for me. The lashcaps were the ticket. I went with Comp Cams 0.080 caps. They corrected just about everything in my geometry. I did have to go with ARP studs being they have a lower profile base nut. I really could of used a 7.150" pushrods but that would of called for clearancing the base of the rockers a tad. I am pretty close to being about 1/3 down the valve stem on the base circle. I don't think it's going to matter that much now. I got the gross problems out of the way.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
